TwinTurbo.NET: Nissan 300ZX forum - Crank and rod bearing replacement
njz
on March 16, 2018 at 4:00 PM
Has Anyone replaced bearing without removing heads, with engine out.
Crank and rod bearing replacement -
njz
16:00:23 03/16/18
Talk to Jesse, pretty sure he's done that... (n/m)
Barry (NJ)
16:52:28 03/16/18
Thank you Barry (n/m)
njz
17:02:21 03/16/18
Yep. If the engine is out, flip it over, pull the oil pan,
MixManMash
17:53:15 03/16/18
Re: Yep. If the engine is out, flip it over, pull the oil pan,
njz
18:51:26 03/16/18
Yes, it’s simple
-Grimm-
21:31:56 03/16/18
Re: Crank and rod bearing replacement
ouikikazz
13:42:57 03/17/18
Why replace the head gasket if there is nothing wrong with
MixManMash
19:56:30 03/17/18
This^ ? (n/m)
ZXoltan
08:37:37 03/18/18
Re: Why replace the head gasket if there is nothing wrong with
ouikikazz
13:17:46 03/19/18
While you're at it...
ZXoltan
14:46:33 03/19/18
You must have low oil pressure if your doing that. Make sure
CmyZ
15:20:28 03/18/18
I'll be doing the same. Motor will be out for some other
Zbullet
09:59:42 03/19/18
